Washing machine drain hose right angle adapter?
Old 02-12-19, 02:47 PM
C
Anyone ever found or made an adapter for a washing machine drain hose that is 90 degrees? Trying to get mine as close to the wall as possible and the one I have sticks out an extra 4 inches.
Obviously I know they make drain hoses with an elbow, but seeing as I just bought this one a couple months ago, I'd hate to spend another $20 if I don't have to. ;-)
Old 02-12-19, 03:50 PM
Received 3,419 Upvotes on 3,065 Posts
Many of the drain fittings on clothes washers are right angle connectors.
Based on what you most likely have..... it's almost impossible to adapt it as you have a hard plastic fitting exiting the case.
Post the model number for the washer.
Old 02-12-19, 07:34 PM
C
It's a Whirlpool WFW86HEBW1 - has a straight fitting coming out the back of the washer. The OEM drain hose has a right angle, but this is the one that I currently have...
https://www.amazon.com/gp/product/B07BGHC4TD/
I was kind of hoping there was the right angle version of something like this...
https://www.homedepot.com/p/100044154
Old 02-12-19, 07:55 PM
I had to look up your machine to see what size the drain fitting is. It's 1"
The smallest size I can find is 1-1/4". Anything smaller is going to be a special order and will cost.
I tried at fernco but their site is under construction.
small rubber elbows.
Old 02-13-19, 08:15 AM
C
Good find. Seeing as these are $15+, I might as well order a new OEM part. Figured it was worth a shot. Thanks!
