can I cut gas pipe with sawzall?
Old 03-07-19, 01:42 PM
Q
Received 1 Upvote on 1 Post
There is a 2" gas pipe that runs throughout the 3 floors of our house. The house used to have gas lighting in every room, so that explains why the gas line is so big.
The gas has been off for years now and we want to remodel but need to cut out these old pipes.
The line is capped so there's no way to release any gas that might be inside.
So, how can I cut this safely given that a sawzall throws sparks?
Old 03-07-19, 02:11 PM
XSleeper's Avatar
Received 1,720 Upvotes on 1,544 Posts
There is no problem cutting the pipe with any tool there is, provided you are sure it is off.
Old 03-08-19, 10:19 AM
Q
no residual gas inside the pipes that could explode?
Old 03-08-19, 10:42 AM
XSleeper's Avatar
At the risk of repeating myself, no.
Old 03-08-19, 01:46 PM
Q
I'm just interested. If the gas was running, there would be a risk of sparks so why not with residual gas? If there was that much gas left around a bbq, it would light up pretty quickly from a flame.
Old 03-08-19, 02:02 PM
XSleeper's Avatar
Because there is no gas pressure! Same reason your bbq grill goes out when the tank is empty!
Old 03-08-19, 03:38 PM
Q
If you run the gas for a minute around a bbq then turn it off there is no pressure but if you light a match, you get a good woompf when it catches
Old 03-08-19, 03:55 PM
Received 32 Upvotes on 23 Posts
To clarify, are both ends of the line capped? Or just one?
Old 03-09-19, 04:08 AM
Q
Just one. The starting end goes to a meter that has been shut off for some time. Other end is capped on 3rd floor - about 50ft of pipe length away.
Pipe is 1.5" diametere until you get to the 3rd where it reduces to a smaller pipe...
Old 03-09-19, 04:28 AM
Received 742 Upvotes on 648 Posts
Can you unscrew the pipe anywhere along the way? Since the gas has been turned off for yrs I doubt there will be enough gas to ignite even if you were to expose it to a spark. .... and if it did, how long could it burn!
Old 03-09-19, 07:53 AM
Q
I can try, not sure whether the pipes are double threaded alternative ways, it looks like galvanized pipe...
Old 03-09-19, 07:59 AM
XSleeper's Avatar
I want you to cut it, then tell me that I was right. If I don't hear from you again I will assume I was wrong. LOL
Old 03-10-19, 02:38 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
Old 03-11-19, 03:43 AM
GregH's Avatar
Super Moderator
Received 66 Upvotes on 61 Posts
Exclamation
Since the pipe you wanted to cut off is still connected to the gas supply and after the piping is removed it will need to be capped off.
You can not assume that the valve works and have to open the end cap or a branch line before working on it.
Old 03-14-19, 05:23 AM
Q
None of the piping has tape on the threads. Presume it wasn't needed decades ago? I opened one of the convectivec - no gas inside.
