I Need a Tool To Remove 3" PVC Pipe Caps
Old 03-10-19, 11:00 AM
I need a tool that will fit the square hole in a 3" PVC pipe cap. The cap has male threads and the diameter of the cap is 3.25".
Where can I buy such a tool?
Old 03-10-19, 11:08 AM
Received 153 Votes on 136 Posts
Without having one in front of me to reference - would a 3/4" ratchet/extension fit? Normally they aren't screwed on that tight, could you get it started turning with a screwdriver and hammer? or maybe pliers inserted in the hole spread out and use it as a handle to turn it.
Old 03-10-19, 12:22 PM
Received 296 Votes on 270 Posts
You can get the wrenches on the internet, from plumbing suppliers and some home centers. Try searching for "plug wrench" or "pipe cap wrench".
Old 03-10-19, 01:08 PM
XSleeper's Avatar
Received 282 Votes on 258 Posts
I would think an adjustable pin spanner wrench would work in a pinch.
Old 03-10-19, 02:10 PM
Received 65 Votes on 60 Posts
Depends how tight it is I suppose, but I've improvised with a piece of flat stock
Old 03-10-19, 02:14 PM
Tolyn Ironhand's Avatar
Received 66 Votes on 58 Posts
Cut a piece of wood to fit the hole and turn with a wrench.
Old 03-10-19, 03:56 PM
CasualJoe's Avatar
Received 38 Votes on 30 Posts
Is this what you are looking for?
https://www.walmart.com/ip/ZURN-Clea...xoCGa8QAvD_BwE
Old 03-10-19, 04:51 PM
Yes, the tool from Walmart is what I'm looking for. I'll probably order the cheaper one ($14) as it will be a one-time-use tool.
HTML code is On
