Delta Faucet
Old 05-26-01, 09:52 PM
Diane DiTomasso
Delta Faucet - Side Handle -- center high faucet.
The center Faucet keeps leaking water out of the bottom of the faucet around the sink. Can you give me any help.
Thank you.
Diane DiTomasso
Old 05-27-01, 01:28 AM
Mike Swearingen's Avatar
Cool
There are two o-rings under the barrel of the spout that prevent this type of leak. When they get worn, they leak.
This illustration is for a single-handle Delta, but they are replaced the same way.
Remove the spout, replace the o-rings, and lube them with petroleum jelly. Easy.
Good Luck!
Mike
Old 05-27-01, 01:29 AM
Cool
There are two rubber o-rings under the barrel of the spout that prevent this type of leak. When they get worn, they leak.
Remove the spout, replace the o-rings, and lube them with petroleum jelly. Easy fix.
Good Luck!
Mike
Edit: Welcome to another post(s) by the computer e-lliterate. LOL
HTML code is On
