Pipe size to shower
Old 03-30-19, 06:39 AM
C
Pipe size to shower
Hi,
Im putting in a walk in shower using Delta products which all use 1/2” plumbing, including inlets. I’m using Pex with home runs to a 3/4” x 1/2” manifold (3/4 in, 1/2 out). I read somewhere that I should run 3/4” hot n cold to the shower and then reduce to 1/2” at the mixer valve. This makes no sense to me. Why would I run 3/4” when the valves and sprays are 1/2”?
Pete
Old 03-30-19, 09:14 AM
CasualJoe's Avatar
Received 99 Votes on 89 Posts
No good reason I can think of, never seen it done that way before. A good reason to use 1/2" pipe is to reduce the time and waste of water trying to get hot water to the shower faucet.
Old 04-01-19, 11:03 AM
Z
Received 175 Votes on 156 Posts
Agreed, 1/2" is quite sufficient for any standard shower/tub (as long as you're not installing a high-end multi-head shower).
Old 04-01-19, 01:18 PM
P
Received 785 Votes on 722 Posts
I have 3/4" PEX trunk lines in my house with individual 1/2" lines T off for each fixture. I've never had any issue with pressure or flow volume but all my fixtures are modern low flow style.
