Toilet won't drain
Old 05-28-01, 01:01 PM
Guest
Unhappy
We had a new toilet installed. The toilet won't drain. When the other toilet is flushed, the new toilet gurgles. I have snaked the line and can't find a clog.
Old 05-28-01, 02:45 PM
Received 133 Votes on 123 Posts
It's very possible that your main plumbing vent is clogged, or even possibly your main drain line is clogged or obstructed. Several people suggest trying running a water hose down the roof vent pipe(s). If it's just leaves or a bird nest it may well solve your problem.
Old 05-28-01, 02:47 PM
Mike Swearingen's Avatar
Cool
Have you checked the vent stack pipe on the roof for clogging with birdnest, leaves or debris, and flushed it with a water hose sprayer?
Have you snaked the toilet itself with a toilet auger? A toilet has its own built-in trap, and that's where it is most likely to clog.
Must be one or the other since you've snaked the line.
Good Luck!
Mike
