Testing Hot water heater elements
Old 05-29-01, 08:14 AM
Guest
Smile
How do you test to determine which heater element in a hot water tank isn't working?
Old 05-29-01, 08:27 AM
Mike Swearingen's Avatar
Cool
I'm not a plumber, but here's how I test:
A. Turn off power breaker to water heater.
B. Disconnect both wires from each element.
C. Test for continuity with an ohm meter. No continuity, replace it. Usually the lower element goes first, but I always replace both while I'm at it, if one goes bad.
Good Luck!
Mike
Old 05-29-01, 08:29 AM
Plumber2000's Avatar
Old 05-29-01, 09:04 AM
Guest
Wink Thanks
Thanks Guy's much appreciated
