Leaking pipe cap
Old 05-27-19, 03:20 AM
Exclamation Leaking pipe cap
Hi this is my first post, recently i remove a part of my piping and capped it. The issue I'm having is that i can't get the cap to be water tight. This is even after I've put a godly amount of white tape. attached are the before and after picture for perspective. Any advise on what i can do to get it water tight?
Old 05-27-19, 03:43 AM
Norm201's Avatar
That's a compression fitting. You need to buy a 3/8 ? compression cap. You do not use TFE tape. with it. It will have an "O" ring to seal the fitting.
Old 05-27-19, 04:48 AM
Thank you, do you have an image for reference? My hardware store here mostly deals in Mandarin ...
Old 05-27-19, 10:05 AM
Compression caps are pretty rare. Your local store may need to order it for you or you can order it online.
Old 05-27-19, 10:36 AM
A compression cap should come with a ferrule. I'm not sure if a cap will work by itself.
It's been a while since I've capped one off.
Old 05-27-19, 03:08 PM
lawrosa's Avatar
Super Moderator
Get one with the rubber seal inside.. check the home store
Norm201 liked this post.
Old 05-27-19, 03:41 PM
Norm201's Avatar
What Lawrosa said. We carry them in 3/8 and 1/4
Old 05-29-19, 03:34 PM
CasualJoe's Avatar
But, is your store in Singapore?
Old 05-29-19, 05:46 PM
Norm201's Avatar
No but a lot of stuff we carry is from China.
HTML code is On
