Outdoor timer / water hammer fix?
Old 06-03-19, 04:39 AM
I have an outdoor timer on my hose spigot, that turns on in the morning for a drip line. Every time it turns on I hear a loud bang. Any way to correct what I'm assuming to be water hammer?
Old 06-03-19, 12:41 PM
I've never heard of water hammer when turning on a device.
Usually it happens when the device is turned off.
If you have high water pressure the valve could be chattering. You'd need to check the house pressure with a basic 3/4" test gauge from one of the home improvement stores.
Old 06-04-19, 04:28 AM
If you can locate the source of the banging sound you can try and better attach the pipe so it doesn't move and bang. You can also try a water hammer arrestor or install a small pressure/expansion tank in the line.
HTML code is On
