Running toliet
Old 05-29-01, 09:45 PM
Guest
Please tell me how to make my toliet stop running. I even tried cutting it off by the shut off valve, but continues to run. I'm so afraid my water bill is going to be sky high. Please help.
Old 05-30-01, 01:30 AM
Mike Swearingen's Avatar
Cool
Sounds like you need to replace:
1. the flapper at the bottom of the tank,
2. and maybe the water inlet valve assembly (use a FluidMaster float-cup type), and
3. repair or replace the cut-off valve,
to get everything back in good working order.
Should be less than $10-$20 in parts.
You'll need to cut-off the main water valve to your house.
See "Repair/Fix-It" above and go to http://www.bhglive.com/homeimp/ for illustrated how-to info.
Good Luck!
Mike
