How to support irrigation PVB assembly above ground?
Old 07-22-19, 12:12 PM
Z
Here is my irrigation PVB assembly:
It used to be connected to a galvanized tee (just hidden behind the leaf there) and suspended by the galvanized water supply pipe to the house.
I've since replaced the galvanized pipes in the house with copper pipes. But they won't be able to physically support the weight of the PVB assembly.
I'm thinking of some sort of pipe bracket/stake combo to support them to the ground which will allow easy disassembly and repair when needed.
Is there such a product or can I build one easily? Or is there a better way to support it without mounting it on the masonry?
Thanks.
Popular Reply
07-22-19, 03:05 PM
Marq1's Avatar
Marq1
Marq1 is offline
Received 488 Votes on 452 Posts
I would attach a piece of pressure treated wood or a piece of Unistrut to the wall and attach the pipe structure to it.
Tapcons into the grout line are easy to install, secure, and if removed easy to patch, dont drill the brick!
Old 07-22-19, 03:05 PM
Marq1's Avatar
zaydo, Zorfdt voted this post useful.
