drain back up
Old 07-26-19, 06:50 PM
P
drain back up
I am new here seeking advice.
PROBLEM....
after using bathtub when draining BOTH bathrooms get flooded. they are oposite on same wall. Commodes are back to back.
I am disabled and limited on what I can lift....commode is 1 of them.
the water leaks out around both commodes, fills the shower stall in other bathroom.
when flushing commode it works and no leaks,shower, something although shower drains kinda slow.
plumber wants $250 to run a snake....I live in real area on septic....and on a VERY tight budget.....I have plungdered tub and also shower....tub .. no help....shower I get some small black "moldy" looking chunks.
wife wants to use liquid plumber .... we have PVC Piping....but I fear it could cause problems with septic.??????
have heard of shop vac trick....how could I achieve fixing my drain without putting my septic at risk
Old 07-26-19, 06:59 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Sunds like you have a clog after toilets and septic, If there is a clean out you could try to run a snake from there.
Old 07-26-19, 07:02 PM
Received 3,973 Upvotes on 3,566 Posts
Welcome to the forums.
The best way to protect a septic is to never use any drain cleaners.
If your showers/tubs are back to back..... the problem is the stack in the wall. There isn't much you can do without snaking it. The "vacuum trick" could possibly work but is not terribly helpful in that situation.
Norm201 voted this post useful.
Old 07-27-19, 03:46 AM
P
Received 2,180 Upvotes on 1,950 Posts
Another vote for snaking the drain line to clear the clog. Using water in one location causing water to back up in another is a classic sign of a clog unless you've previously had signs of a septic problem. The clog is somewhere downstream of where your bathrooms connect to the main drain.
Don't waste your money on pour down the drain chemicals as they don't work.
Old 07-28-19, 05:57 AM
C
Received 25 Upvotes on 22 Posts
In this situation, could Pawpadog (the OP) snake the drain himself using a rotary drum snake? Either manual or with a drill?
