Adding NG line from meter to grill
Old 08-15-19, 09:34 AM
Question Adding NG line from meter to grill
Hello,
I'm trying to add a gas line to my grill from the meter. The grill It is about 10-15 feet from the meter which is nice. What I'm trying to find out is, where is the best place from the meter to add the Tee?
Thank you very much for your help.
Old 08-15-19, 09:56 AM
Received 17 Votes on 16 Posts
I would add the tee in that upper section above the union. Makes it real easy to remove and replace. Plus keeping the union attached to the meter makes it easy for the meter to be replaced if/when needed.
Old 08-15-19, 10:06 AM
Thank you for the prompt reply.
Just to make sure, leave the coupling above the union and replace the longer pipe in the upper section with two smaller pipes and a tee in between?
Thanks again.
Old 08-15-19, 06:08 PM
Received 260 Votes on 245 Posts
Take the coupling right above the union out and replace it with a tee. If the tee is slightly larger than that coupling..... you may have to use a shorter nipple from the union to the tee.
Reduce down to 1/2" for the BBQ line.
That meter has a yoke with two unions on it for meter replacement.
Helpful stuff......
If you go to a place like depot...... get several different sized nipples in case you need to replace the short one. I always buy extras and duplicates and return what I don't need. Many places like the depot make their own threaded nipples and they are #1 not always all the correct length #2 some have crappy threads. Use joint compound.... not teflon tape.
Old 08-16-19, 08:43 AM
Pete,
Thank you very much for the info.
Forgive me, but you said replace the coupling with a 90. Where does the tee go? Are you saying replace the coupling with a tee then add nipple and a 90 then run the line to the BBQ?
Thank you,
Old 08-16-19, 09:24 AM
Sorry about that. I corrected my reply to say tee instead of 90.
Old 08-19-19, 06:49 AM
Thank you, Pete! I was able to get it done!
Is it okay to use a reducing bushing to reduce the tee into a 1/2 or a bell reducer is required for gas if I can't find a reducing Tee?
Old 08-19-19, 09:37 AM
Received 21 Votes on 17 Posts
That would be a question for your LOCAL code enforcement agency. Many years ago bushings were specifically prohibited in fuel gas piping but now many, but not all, local codes do accept the use of bushings.
Personally, I do not use bushings. There is/was also a prohibition on using street ells that may no longer apply in all jurisdictions.
Old 08-19-19, 09:38 AM
Malleable iron bushings would be OK but cannot be differentiated from the cast type so typically reducing bushings are not allowed.
Reducing tee's are acceptable as well as bell fittings.
Old 08-19-19, 10:29 AM
Thank you both for the reply.
I'll switch to a bell fitting.
Thanks again!
HTML code is On
