Gas pipe extension downward?
Old 08-18-19, 10:33 AM
In my house, every gas connection that goes up also has this 6-10" down connection with a stopper. Is this necessary and if so why?
Old 08-18-19, 01:35 PM
Received 330 Votes on 308 Posts
That piece pointed downwards is called a drip leg.
Any water, moisture or crap will fall down into that stub rather then going into the appliance.
Old 08-18-19, 02:40 PM
So when you connect a flexible pipe to somewhere else does it need to have a downslope or is it only for the incoming connections?
Old 08-18-19, 04:13 PM
A drip leg is typically installed right before each gas appliance.
Easy to do on a furnace or water heater. Not as easy on a gas stove.
Old 08-18-19, 05:02 PM
I have a crawl space so could do one maybe 5' below the fireplace or hob.
Are you supposed to clean them out every so often?
Old 08-18-19, 05:03 PM
That would work and no.... I've never had to clean one out before.
Old 08-18-19, 06:35 PM
What's the code requirement for size of pipe for the drip leg?
Old 08-19-19, 02:14 PM
For example you connect flex pipe to threaded and then below the fixture do you have to add more threaded pipe?
Old 08-20-19, 10:07 AM
Received 19 Votes on 18 Posts
I've never seen a drip leg on the end of a flexible pipe connected to an appliance. I've always figured they should be installed whenever possible, but when it's impossible (like a range), they aren't installed.
As for length, it seems to be a regional thing. Around here, it's usually a 6" nipple. Though I've seen as short as about 2" and longer than a foot.
The goal is to catch little flecks of metal or moisture. Even opening one after 40 years, it's doubtful you'd actually see anything fall out. But it's cheap insurance so you don't have to get stuck cleaning the burner orifices. I've never seen any actual research on how well they work, I may have to do some reading.
HTML code is On
