Replacing Bathroom Vanity Hose
Old 09-02-19, 04:17 PM
Hello,
I have a leak in my bathroom that I figured coming from the cold supply line. I found out this by shutting down the cold supply line and the leak stopped.
For this, I am trying to change my cold supply hose and it appears like the hose and the connector are one single part instead of two (1 Connector and 1 Hose).
Can someone let me know if this involves removing the whole assembly?
Pic attached.
Thanks!
Old 09-02-19, 04:23 PM
XSleeper's Avatar
Received 1,710 Upvotes on 1,534 Posts
Not really a good angle... we can't see if there is a nut on the end of the supply line, or what sort of pipe fitting the shutoff has.
Supply lines usually look like this: https://www.homedepot.com/p/BrassCra...0A-F/100459572
Old 09-02-19, 04:24 PM
Norm201's Avatar
Received 668 Upvotes on 591 Posts
Yes, you are correct, it's one piece and both valve and hose need be replaced. But as individual parts.
Is the valve soldered on? If so it looks like you have plenty of copper extending from the wall. Buy a shark-byte valve and a stainless steel braided hose. The valve will be 1/2 with a 3/8 connection for the braided hose.
Old 09-02-19, 04:28 PM
Thanks for your reply!
I have attached another picture.
Old 09-02-19, 04:34 PM
Norm201's Avatar
Not necessary for another pic. It's very clear to me. Cut the valve off smooth the edges and add a Shark-bite.
This is what you want
Old 09-02-19, 11:49 PM
Marq1's Avatar
Received 1,101 Upvotes on 1,001 Posts
So I'm not familiar with PEX but is that what the red and blue lines are in the picture?
Old 09-03-19, 02:49 AM
Norm201's Avatar
Didn't realize the piping was or could be PEX. however... SharkBite Universal brass push-to-connect fittings are compatible with PEX, Copper, CPVC, PE-RT and HDPE pipe. SharkBite fittings come with a PEX stiffener pre-loaded into the fitting for PEX, PE-RT and HDPE. The PEX stiffener does not need to be removed for Copper or CPVC applications.
Old 09-03-19, 10:02 AM
Z
Received 366 Upvotes on 326 Posts
Agreed with the others. It's definitely PEX (plastic) piping. Norm's suggestion of cutting that one off and using a SharkBite valve is a perfect solution. I'd suggest investing in a plastic pipe cutter ($15-20 at HD). You could use a small saw or knife too, but it'll be a bit of a struggle without a cutter.
You could also get a PEX crimp or expansion tool and redo it that way, but I don't think it's worth it for a single fix.
I would consider replacing both the hot and cold at the same time though. I hate those all-in-one shutoffs. The builder saved maybe $5 on each, but now is a pain in the rear to replace. Once you replace the valve and a braided hose to the faucet, you'll never have to worry about them again!
