Determing if plumbing inside wall is OK
Old 09-03-19, 11:36 PM
Y
Was recently replacing a rusted-on hose bib. The bib attaches to a pipe that comes out from stucco (and is likely connected to a joint that is between stucco and drywall).
In the course of trying to turn the bib, I managed to turn the pipe it was on by a 1/8 to 1/4 turn. I turned the pipe back to its original position (and replaced the bib), but now I'm worried that, behind the stucco, the pipe is leaking because I've deformed the dope/tape that was sealing the threads. Am I being paranoid? Should I be worried about this? If so, is there a good way to determine if the plumbing in the wall is still OK?
Top Answer
09-04-19, 04:27 AM
Pilot Dane
Pilot Dane is offline
Received 1,846 Upvotes on 1,653 Posts
It's probably NPT threaded. About all you can do it tighten the pipe nipple in the wall pretty hard and hope. Other than that you can get a bore or endoscope and drill a little hole or shove it in through the gap around the pipe and see if there is a leak.
Old 09-04-19, 04:27 AM
P
Pipsisiwah, yarrvvee voted this post useful.
