Grundfos recirculating pump and bypass valve
Old 09-16-19, 11:14 AM
Installed this pump and bypass valve in my 2900 sq. ft. newly repiped home, on new Rheem 50 gal water heater. Solved my long wait hot water problem, BUT COLD WATER
NEVER GETS COLD AT FAUCETS!!! Any help greatly appreciated!
Old 09-17-19, 09:43 AM
Received 19 Votes on 18 Posts
The bypass valve probably pushes warm water into the cold water line, allowing hot water to be at the faucet at all times. So it's not uncommon for the cold water to be lukewarm for a little bit... but you should of course get cold water after a minute.
If you're really not getting any cold water, the bypass valve is either plumbed incorrectly or is defective, pushing hot water directly into your cold tap.
Are you sure the cold water shutoff is turned back on? Can you take a picture of your setup? Maybe there's something we can see that would help.
Old 09-17-19, 11:18 AM
Thanks very much for your response! I'll take pix of the Grundfos unit on the water heater and of the valve setup at the kitchen sink. Thanks again. Any advice gratefully accepted!
Old 09-17-19, 12:30 PM
Attached pix of installation
The first 2 photos are of the heat activated valve installed under the kitchen sink.
The next two photos are of the Grundfos unit installed atop my water heater in the basement.
If more or more specific pix are needed, please let me know.
See anything amiss?
Thanks,
Joe
HTML code is On
