Understanding an Odd Leak
Old 10-13-19, 09:47 PM
Received 1 Upvote on 1 Post
I have a strange leak I cannot figure out. After the driving rain this last week, I found a water stain on a wall, about midway between the floor and the ceiling. No stains on the ceiling. There is no pipe behind this wall either.
When I went up into the attic, I found a horizontal vent stack runs across that wall which might leak, but I don't understand how it could leak and not affect the ceiling.
Can anyone shed some light on this issue?
Old 10-14-19, 02:24 AM
Received 741 Upvotes on 647 Posts
Water can take strange routes. It sounds like it followed lumber down until it found a place to exit into the drywall. Did you see any stains on the rafters?
Old 10-14-19, 06:45 AM
No. I went up there looking for leaks from theroof. I didn't uncover the pipe other than just discover it. I will look for that. I's a new house, so Ive got a warranty. Im calling them today.
Old 10-14-19, 08:55 AM
Wind driven rain thru the siding is also a possibility.
Old 10-16-19, 08:02 PM
Got the builder out here, his crew found that the horizontal Vent Stack was leaking (big storm last week) Not enough to ruin much, but they took out the insulation and added a cap to teh vent stack to prevent that in the future. I will probably go up there myself and add some PVC cement around the edges of the elbow join.
Thanks for the input.
Old 10-17-19, 04:11 AM
P
Received 1,768 Upvotes on 1,581 Posts
A cap on the vent stack is a Band-Aid fix. I assume they found a leaking joint in the vent that probably was not glued. Instead of fixing the leak they put a cap on the roof to prevent rain water from entering the vent.
Old 10-17-19, 10:05 AM
Z
Received 367 Upvotes on 327 Posts
Agreed with Pilot Dane. It's a fine short-term fix, but a vent is required for a properly working drain system. By capping it, you're opening yourself to potential issues with traps being sucked dry and sewer gasses entering the house, and possible drain flow issues.
Make sure they fix the actual problem of the broken or non-cemented pipe - especially while your house is still under warranty.
Old 10-17-19, 11:08 AM
P
I should not have said "cap". I'm sure (really hope) they installed a 180° so the opening faces downwards or did something like a chimney cap to prevent rain from getting into the pipe.
Zorfdt voted this post useful.
