Water Pressure Increase
Old 11-14-19, 10:17 AM
R
Pressure has never been great in this house. City water. Can I nudge water pressure at regulator up a bit? I understand too much is not good. I just don’t want to pay a plumber to turn a screw. Bad idea?
Old 11-14-19, 10:20 AM
Received 3,416 Upvotes on 3,063 Posts
Do you even have a pressure regulator ?
Most houses do not.
Old 11-14-19, 10:37 AM
R
Yes, it is easily accessible under my house. I’m concerned about flying blind without a pressure gauge. I want to loosen set nut and tighten 1/4 to 1/2 turn at a time, checking after each increase.
Old 11-14-19, 11:07 AM
P
Received 1,763 Upvotes on 1,576 Posts
That's a pretty poor plan. Are you going to go up 1/2 turn until something blows? Get a pressure gauge.
Also don't confuse pressure and volume. They are two different things. You can have good water pressure but if your old water lines are mostly corroded closed you will have poor water flow (even though you have good pressure).
Old 11-14-19, 12:19 PM
W
Received 60 Upvotes on 52 Posts
This is a gauge which attaches to your hose bib.
Old 11-14-19, 12:58 PM
R
That is why I asked. With the pressure gauge attached to hose bib what is a good pressure limit? 60 psi?
Old 11-14-19, 03:54 PM
P
Ah, if you had asked that question...
Maximum recommended pressure is 80 psi. I would try 50 or 60 first to see if you are happy with the pressure. More isn't always better as it puts more strain on your plumbing.
Old 11-14-19, 04:15 PM
R
You are correct sir. I wasn’t aware of a hose bib gauge. Now I can almost be a plumber Thank you, I appreciate the replies.
