Nat. Gas Heater Addition with specs.
First post, thanks all for any help available. I'm weighing my options on installing a NG heating unit.
Please see spec sheet attached.
Questions are:
- New proposed line would be 3/4, I'm planning.
- Will my current pipe diameters handle the addition.
- The chances of all appliances running at the same time is virtually zero.
Again, thanks for your time.
Questions are:
First I would check your gas meter to make sure it can deliver the gas volume needed. Even if you don't think there is a chance all appliances will be on at the same time... you should still plan for it because Murphy's Law says it will happen on a really cold Sunday morning.
My math shows the piping will handle it, most of it is right on the edge - but within the pipe sizing constraints.
1" main at 65 ft supports 247k btu.
You can pipe to the heater with 1/2"
Does not matter. code is code. But your borderline with any fudge factor.
Thanks to you each. Few follow up thoughts:
I will eventually be adding an outside NG grill to this system at 48K btu, probably about 5yrs out.
- The stub is off of the 1", 9ft run directly beside the boiler.
- The proposed grill line would run 25ft.
- I imagine all 1" would need to be replaced with 1-1/4" to handle proposed heater & grill eventually?
I realize I could work on this with the charts, but instead of reinventing the wheel, I'd feel better listening to professionals who do this work everyday.
Well down here in the south the gas companys often increase the psi to a 2psi system.
That will increase the line to 1million BTUs say.
Then you need a regulator at each appliance... 40 bucks a pop..
Thanks, I'm in CT. I don't believe they do the psi pop. I asked my boiler installer 2 yrs ago when they installed about these "hypothetical additions" and he said 1-1/4" is likely, but he would have liked to run the numbers on the chart again. This is where my assumption came from.
Thanks again for your thoughts.
1 1/4 get 486k. run up to boiler tee..
less then 2psi chart .5" pressure drop...
http://ecodes.biz/ecodes_support/fre...tallations.pdf
