plumbing in a water softener
Hello, I purchased a water softener cheap and looking to install it. I have a question about plumbing it in, which line should I tap in to? Thanks
After the main and before the hot water heater!
Sorry, that plumbing looks to be a mess, I hope you complained!
Street to softner then back into other pipe and heater.
I would assume the line in would be the one with the valve on it. It’s hard to see in the picture. I was thinking of teeing off after the valve taking it to the softener and coming back in after the 90. That other line I wasn’t sure about. And if I can’t get it to work, I’m only out $50 for the softener.
$50 softner, sure it works? Fair amount of work to then find out it's junk!
