How should I connect these pipes?
Old 02-18-20, 04:31 PM
A
Received 2 Upvotes on 2 Posts
This is a vent pipe in the attic. As you can see, I've temporarily moved the rubber coupling to show what's under. I'm looking for a better, more permanent solution because the coupling leaks a bit.
Old 02-18-20, 04:52 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Get a sawzall with a fine blade. Cut the ends off and cut enough from one side to leave a gap.
get two mission couplings.. no hubs copper to pvc.. Use both no hubs and put a piece of pvc between..
One side of the no hub is thicker then the other as copper is smaller diameter.
https://www.homedepot.com/p/Fernco-P...-100372289-_-N
CasualJoe voted this post useful.
Old 02-19-20, 09:40 AM
Z
Received 366 Upvotes on 326 Posts
It looks like that coupling was horribly over-tightened, which probably led to the leaking.
If it were me, on a vent, I'd probably just replace the coupling. But admittedly, Lawrosa's solution is the better.
Old 02-19-20, 10:23 AM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
It's a vent in the attic, what could leak? Shouldn't be any liquid in that area of the vent except for a few raindrops.
Old 02-19-20, 11:24 AM
A
It's from rain coming in through the roof vent. We've had some heavy, sustaining rains so that would do it. And granted, the insulation wasn't soaked, but it was/is damp.
Old 02-19-20, 12:20 PM
H
Received 277 Upvotes on 237 Posts
Agreed
IIWY- I'd get some emery cloth, clean up the corrosion, slide on a new plastic coupling, wrap the break a few times with HVAC metal tape, and then install a new plastic coupling.
