re circulation hot water
Old 04-04-20, 04:48 AM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
Just moved into a new to me house. Hot water one end of house and shower at other end. Will a gravity type re-circulation system work going through attic? Tap into hot water near shower and than run it to drain of tank?
Old 04-04-20, 05:47 AM
B
Received 235 Upvotes on 208 Posts
What size pipe and elevation change would be helpful.
Old 04-04-20, 02:22 PM
pugsl's Avatar
Have not checked into this yet. Just moved into house start of this week and am planning a bathroom remodel so pipe sizes can be adjusted. 8 ft ceilings and probably a 4 fool rise.
Old 04-05-20, 05:58 AM
B
Old 04-05-20, 08:22 AM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
What type of water heater? Electric or gas?
I would get nothing but an on demand unit. This you can use with recirc line. Put at the water heater.
I would deep 6 the motion sensor and wireless transmitter and hard wire that door bell button somewhere near the vanity.
https://www.tacocomfort.com/products/systems/instant_hot_water/genie/index.html
Old 04-05-20, 10:02 AM
pugsl's Avatar
Electric water heater. Starting to look into pumps but wanted to see if passive system would work Just a guess but I think about 40 feet from heater.
Old 04-05-20, 03:13 PM
W
Received 13 Upvotes on 11 Posts
Hi, About 10 years ago I replumbed my house in the attic. Water heater on one end and deep sink and washer on the other end. About 40 feet. I connected the return at the end of the hot water line over the deep sink to the drain on the hot water heater.I put shut off valves on each end the return line in case I wanted to shut it off.A little gravity and convection were involved. Long story short it works great. No pump.
Good Luck Woodbutcher
Old 04-05-20, 08:13 PM
lawrosa's Avatar
Super Moderator
electric bill will go up .. use a on demand type system.
Old 04-10-20, 03:20 PM
Received 6 Upvotes on 4 Posts
My own house has a similar rise (hardly any) and the hot water recirculation works by convection only. When I pipe a recirc, I'll add two valves in case it does need a pump, but see if it'll work by convection first. Mine didn't need a pump.
Old 04-10-20, 04:44 PM
lawrosa's Avatar
Super Moderator
You would have to remove the heat traps in the nipples
Old 04-11-20, 12:41 AM
pugsl's Avatar
Bathroom work in near future, Just moving in and still a lot of panning to do. Will be back with many questions as I know have a 23 x 30 work shop to design and fill..
