What are these two pvc pipes on outside house wall for?
Hello - I have these two on outside wall. the left one is dripping leaking water.
What are these for?
Is dripping normal?
Anyone knows??
What are these for?
Is dripping normal?
Anyone knows??
What are these for?
CasualJoe
voted this post useful.
Judging by the size and appearance, it's 1/2" or 3/4" copper. The size used for condensation or overflow. Water heater fittings are brass so that makes sense. Furnaces are larger pvc pipe and intake and exhaust are always separated by more than 2 or 3".
Those are not air lines for a furnace. If you are currently using the A/C..... it could be condensate. Since there are two lines..... one may be primary and the other secondary or overflow.
As mentioned.... it looks more like copper pipe....not PVC.
What that means to you...... the condensate should always come out the same line. If you see it come out of the other other it means the primary drain is clogged and requires looking into.
If you are not currently running the A/C..... you'll need to see what's close to these lines inside.
