3/4 in ball valve sweat
Old 04-20-20, 01:25 PM
P
I just installed a 3/4 ball valve sweat and it is leaking. It is leaking at the seam. Is there a way to fix it. I tried to tight in but no help.
Old 04-20-20, 02:11 PM
XSleeper's Avatar
Received 1,696 Upvotes on 1,522 Posts
Possibly you applied too much heat, too long, and cooked it.
Norm201 voted this post useful.
Old 04-20-20, 02:36 PM
XSleeper's Avatar
See step 10 in this video. They also suggest soldering with the valve open and using solders with lower temp melting points.
Old 04-20-20, 03:09 PM
Received 3,409 Upvotes on 3,059 Posts
Once it's sweated in place.... there is no way to tighten it.
You'd have to take it out to tighten it up..... or at least unsolder one end.
Old 04-21-20, 04:18 AM
Received 257 Upvotes on 230 Posts
OK I have never done this on a fitting like this so it is a bit of a shot in the dark.
Get a strip of thin rubber or something like rubber etc. In my case I used Nalgahide, I think that is what it is called. It was left over from a snowmobile seat re-cover project. In the old days we always had inner tubes.
Wrap it around the fitting a couple times.
Then put a clamp over it and tighten it up.
Might save you from having to unsolder everything.
Note that I would check that the ball valve is actually shutting off properly before doing anything.
Old 04-21-20, 04:54 AM
Norm201's Avatar
Received 663 Upvotes on 586 Posts
When sweating any kind of valve, you remove the innards so the heat doesn't cook the seals. That is what I think you did. Remove and replace valve.
