water pressure tank
Old 06-09-01, 04:55 PM
Guest
I have a deep well pump and a water pressure pump. I lost all water pressure. How do I re-pressurize my pressure tank?
ie what is the procedure?
Luc
Old 06-09-01, 07:39 PM
Mike Swearingen's Avatar
Cool
If you have a bladder-type pressure tank, check the minimum pressure with a tire gauge.
It should be at the cut-on pressure (or two psi below), and if not, air it up with a bicycle pump or portable air tank or compressor.
Good Luck!
