Cheap water pressure activated valve
Old 05-25-20, 03:20 PM
H
Received 1 Upvote on 1 Post
I have a 3/4 inch PE pipe that siphons off a large pond, the surface of which is maybe 10 feet higher than the output end of the pipe.
I connected a garden hose to the end and put a sprinkler on it. The pressure is sufficient to operate the sprinkler. Now I want the sprinkler to spray only when the water pressure in the hose reaches a given point, stop when the pressure drops, and so on.
The application is to water a vegetable garden and be a scarecrow at the same time. I figure if the sprinkler only goes off intermittently it will both startle animals and keep the garden watered. It is the laziest solution I could think of to satisfy both needs, and because I am also cheap I would like to spend as little as possible on it.
Maybe a solar powered timer is a better solution?
Old 05-25-20, 04:22 PM
Received 3,422 Upvotes on 3,068 Posts
Since there is no pump..... what will cause the pressure to go up and down ?
It sounds like a gravity feed system. If the pressure goes down it means the pipe is out of the water. How will the siphon restart ?
Old 05-25-20, 04:45 PM
H
@PJmax The pressure seems to drop when water has been flowing for a few seconds, then builds back up when the hose is shut off for a few seconds. The intake is never out of the water.
Old 05-25-20, 04:49 PM
Ok..... now I'm more confused. You want a valve that keeps closing/opening every few seconds ?
Old 05-25-20, 05:20 PM
H
@PJmax yes, or as frequently as the pressure changes.
Old 05-25-20, 06:17 PM
Z
Received 367 Upvotes on 327 Posts
I found a 5psi pressure switch
https://www.amazon.com/Pressure-Swit.../dp/B0078RMKTM
So in theory, this connected to an electronic valve might do what you're looking for... maybe?
But it sounds like it would cycle on and off every few seconds. I can't imagine that's a good plan.
Instead, I would pick a hose timer. Has nothing to do with water pressure, but battery powered and can turn on and off a few times throughout the day.
Something like this (I just picked the first one in the list, no idea how good/bad it is)
https://www.amazon.com/Instapark-Out.../dp/B01M676JAS
