Well pump: Swing or Spring check valve?
I am moving my well pump equipment into a new building that I am finishing. It currently has a very old 1-1/4" spring check valve downstream of the pump. Since I am redoing everything I plan to install a new check valve, I just took delivery of a 1-1/4" swing check valve. After looking at it I am concerned that it will allow water to backflow down into the 170' deep well. It is simply a brass flapper that is pressed against a brass seat with back pressure when the pump is not operating. There is no gasket or other seal.
I am curious what others use in their well setups, and if you've had issues with swing valve allowing water to flow backwards through them? Thanks.
Video link
Video link
Welcome to the forums.
The brass on brass is a very effective seal. It allows for the most flow of water. The spring type are somewhat restrictive. The most important thing with a check valve is that it gets installed oriented correctly. Some are horizontal only... some are vertical only.... some don't care.
I don't have a well so I don't use a check valve.
Many of our members do have wells and will stop by to comment throughout the day.
