leak at base of bathtub
Old 06-11-01, 07:53 AM
Guest
Cool
I have noticed a leak at the front base of the tub whether the shower or the tub is used. Water accumulates at the seam of the floor just at the front corner of the tub.What do you think?
Old 06-11-01, 02:56 PM
Guest
NEED A LITTLE
MORE TO WORK WITH?
DO YOU HAVE SHOWER DOOR?
CURTAIN?
ANY STAINS ON CIELING BELOW?
FIRST OR SECOND FLOOR CAN YOU GET AT THE DRAIN?
IS THERE A CLOSET TO SEE IF THE SHOWER VAULVE IS LEAKING?
Old 06-12-01, 05:36 AM
Guest
Cool bathtub leak
This is an older house, one story. The bathtub has a curtain. I do not see any stains on the ceiling or wall. The water appears to go down the front side of the tub where the wall and tub meet and then on the floor. Hope this additional information is helpful in solving my problem.
Old 06-12-01, 06:14 AM
Plumber2000's Avatar
Debra,
Make sure all the trim for the valve is tight to the surround, including the tub spout, and caulked for a water tight seal, any gaps that could be there can allow water to get into that wall and shortly arrive on your floor line.
What kind of surround is there, tile? It could be bad grout.
Old 06-13-01, 08:06 AM
Guest
Cool leak around bathtub
Yes, its tile.
Old 06-13-01, 08:40 AM
How old is the tile? If the tile grout sealant is bad, water can pass right through the grout lines, and you never even know it's happening. This is only a possibilty, check all other sorcces before deciding it's the tile.
Old 06-13-01, 10:55 AM
Guest
Thanks for the input. I'll check all possibilities. Will keep you posted.
Thanks again.
