How to replace propane gas hose on fire table?
Old 06-14-20, 09:40 AM
B
Received 1 Vote on 1 Post
Iíve got a fire pit that came with a real short hose - maybe 7í long. Would like to replace it with a longer one, but donít know how to accomplish that. Do I need to re-use the same regulator (see photo)?
Noob question I know...
Old 06-14-20, 10:06 AM
Received 1,112 Votes on 1,032 Posts
That regulator and hose is an assembly. The hose isn't changeable.
You can purchase an assembly with a longer hose.
Is there a pressure rating on that regulator ?
What length hose were you looking for ?
Old 06-14-20, 03:50 PM
B
Trying to dig that info up. The model on the regulator is JY70-012.
Ideally to have one long enough (~15-25ft) so I can store it somewhere less conspicuous, not right on the deck.
Old 06-14-20, 05:25 PM
I'm not sure if putting the propane tank hidden out of sight is against code.
That's one reason for the short hose..... although there is something to be said for keeping the tank further from the fire pit.
I'm going to check and see if I can get further information
Old 06-14-20, 07:10 PM
B
Thanks!
The fire table comes with a box/covering that matches the finish of the fire pit, so itís arguably out of site as is. Iím considering putting it in a very accessible location, but just around the corner from our deck - not in the middle of everything.
HTML code is On
