Shower drain Help
Old 07-31-20, 09:07 AM
G
Shower drain Help
I am replacing an old cast iron flange with PVC. Found out I have ABS under slab. My issue is the amount of space I have to install new drain/flange. flange and coupling measure 6" I only have 5" to top of slab. What do I do????
Old 07-31-20, 11:00 AM
P
Received 1,759 Upvotes on 1,572 Posts
You can't use a PVC coupling to connect to cast iron. You will need a no hub coupling (rubber boot with metal shield around the outside) to transition between the two materials.
Old 07-31-20, 11:16 AM
G
It is ABS. The old flange was cast iron. once I opened the slab I found the ABS.
Old 07-31-20, 12:44 PM
G
How much pipe do I need (space) in between fittings? 1/2" 1"
Old 07-31-20, 01:20 PM
XSleeper's Avatar
Received 1,701 Upvotes on 1,525 Posts
Slip the shielded Fernco stop coupling over the ABS until it stops. Then measure from the stop to the surface of your concrete and do the math.
Old 07-31-20, 01:55 PM
G
How much pipe do I need in between the fittings or can they right on top of each other??????
Old 07-31-20, 02:19 PM
XSleeper's Avatar
It is not code to glue ABS to PVC. So you would not be using a PVC coupling... So your question is a moot point. You would be using a Fernco and i have no way of answering your question as I'm not there to measure.
Old 08-01-20, 06:57 PM
czizzi's Avatar
That is the bottom part of a multi part shower drain. It should be determined which level in grade. Set the flange you have with previously mentioned fernco couplings. You would then add a preslope to that drain body followed by the introduction of a shower pan membrane on top of the preslope - the membrane should extent 9 " up the wall and be folded over the curb so that there are no cuts that would cause leaks. Once completed a water test is performed and then a normal mudbed in installed to which tile is adhered to this.
Old 08-01-20, 07:08 PM
Z
Received 364 Upvotes on 326 Posts
You can go one of two ways:
1) Stick with ABS. Get an ABS coupler, an ABS flange, and a couple inch piece of 3" or 4" ABS pipe. With a 5" spacing, your pipe will need to be about 4", but you'll have to measure to be sure or the exact length.
2) Convert to PVC. Same exact process, but use a no-hub coupler to convert from ABS to PVC.
BUT - is that a trap? There shouldn't be a trap under the toilet.
