shut off valve will only turn if packing nut is loosened
Old 08-06-20, 10:00 AM
R
I have a shut off valve going to a washing machine but it won't turn unless I loosen the packing nut to the point where it leaks. What problem is going on here?
Thanks
Popular Reply
08-08-20, 04:22 PM
PJmax
PJmax is offline
Received 1,021 Votes on 947 Posts
I would replace those valves with 1/2" threaded valves. Easy to replace after the water is shut off.
They are 1/4 turn ball type valves.
Old 08-06-20, 11:17 AM
P
Received 586 Votes on 540 Posts
The packing is probably worn out and needs replacing. On most valves you can leave the water to the house turned on and replace the packing as long as the valve is in the closed position.
Rolomoto voted this post useful.
Old 08-07-20, 09:04 PM
R
Is there any way to get the nut off with the box in the way? I can't unscrew the handle.
Old 08-07-20, 09:29 PM
I would look into replacing those old valves. They will be hard to work on in there. I'm trying to get a fix on the type of valves you have. The newer valves are ball valves and turn much easier with no nuts to leak. You can take the four screws out of the cover and post a closeup picture of the valves.
Old 08-08-20, 04:36 AM
P
You can use offset (90) screwdriver to get the handle off.
You can use a Phillips socket and socket wrench.
You can also use a screw driver bit like you'd use in a cordless screw driver or drill and turn it with a 1/4" wrench.
Old 08-08-20, 06:07 AM
Received 155 Votes on 142 Posts
I also would replace the valves.
Just be sure that the replacement spigot does not extend too far as you have to be able to turn it inside the cover.
I would stick with the handle type valves as levers can be a pain if they end up oriented the wrong way.
Might not be a bad idea to also replace the hoses as hey look fairly old or at minimum replace the rubber washers.
Old 08-08-20, 06:23 AM
Norm201's Avatar
Received 225 Votes on 200 Posts
If you're going to replace the valve set, go for the single lever that controls both hot and cold.
Old 08-08-20, 08:34 AM
R
Mine are 6" apart, the single lever I've seen are about 2" apart, I don't see any that would fit.
Someone asked for a closeup of the valve, here's a pic:
Old 08-08-20, 09:06 AM
Norm201's Avatar
Actually there is one that will fit.
Might not be worth the effort to change it out.
$39.98
Oatey Single Lever Copper Sweat Washing Machine Outlet Box
Item #596141Model #38568
  • Oatey Quadtro washing machine outlet boxes can be used in commercial or residential applications which require supply Valves and waste drain recessed into the wall
    https://www.lowes.com/pd/Oatey-Singl...E&gclsrc=aw.ds
  • Available water hammer arrestor option provides water pressure shock arrestors required for installation on supply lines to quick closing Valves
  • Fits PVC or ABS Schedule 40 DWV pipe
Old 08-08-20, 09:44 AM
It looks like the valves are threaded on. That's why I recommended changing them.
I wasn't recommending soldering new valves. Need to see below the valves for type of connection.
CasualJoe voted this post useful.
Old 08-08-20, 10:13 AM
R
Thanks...a little too difficult.
Old 08-08-20, 10:41 AM
R
It looks to be threaded on. I can't find the handle type, are shark bites ok?
Old 08-08-20, 01:50 PM
Norm201's Avatar
Well normally I would not recommend Shakbites behind a wall. But in this case I'd be willing to go for it.
But why? The valves are screwed on. Easy enough to replace.
Now days most of the isolation valves are 1/4 turn. No more washer type.
Old 08-08-20, 04:22 PM
CasualJoe, Rolomoto voted this post useful.
Old 08-08-20, 04:32 PM
Received 3 Votes on 3 Posts
PLUS ONE on Changing _ Out
Yeah ,Just Change them , as the Blue on the one says it's Corroded Up and Way Easier to use and Open Wrench
on those or Plumber Wrench . . Then After those are Off ~ U ~ Rebuild . . and Sell Them ~ Fast ~ LOL
No You could save them if this is something U do Offend . .
Old 08-08-20, 04:53 PM
R
my local store only carries the color coded in a very long stem variety, would that work. The other option is something called a boiler drain, would that work?
Old 08-08-20, 07:04 PM
Norm201's Avatar
Yes you could use the boiler drains, but that would be no, better than what you already have.
Old 08-08-20, 07:31 PM
R
PjMax:
I'll go with these, strange but Amazon is the only place that sells them apparently.
Old 08-08-20, 08:27 PM
R
Should I use Thread Seal Tape?
Old 08-08-20, 08:37 PM
Yes.... that is a tapered pipe thread and requires teflon tape or thread sealant.
  #21
Old 08-18-20, 11:19 AM
R
Any suggestions on how to break these valves loose, I can't get them to budge.
Thanks
  #22
Old 08-18-20, 11:43 AM
Norm201's Avatar
Two pipe wrenches and maybe a cheater bar om each.
  #23
Old 08-18-20, 05:04 PM
R
Got them in, thanks for the help!
  #24
Old 08-21-20, 09:45 AM
Z
Received 102 Votes on 95 Posts
If at first you fail, get a bigger wrench (or hammer)
Glad to hear you got them replaced!
HTML code is On
