THE HYRDA SHOWER
Old 06-13-01, 12:50 PM
holland_patrick
Question
As you well know the hyrda was a multi head monster in the past. well i want a mutli head shower. I have a raised ranch and will be putting a shower in the master bathroom. which only have a toleit and a sink. do any of you plumbers have any good thought about which company is good? kolor detla i know make the set ups but any info will be good.
ps town water so it's good pressure.
Old 06-20-01, 04:44 AM
abNORMal's Avatar
I'd check out Kohler first.
One tip:
With a multiheaded shower, or one with body sprays and the like, the volume of water coming out is sometimes too much for the drain to handle. Make sure the drain is adequate to handle the flow. You should pay attention to the flow rates of the heads you're considering, and the flow rate of 2" 3" and 4" drains, and match them accordingly. Also make sure that the shower pan is deep enough to prevent excess from overflowing onto the floor.
Old 06-20-01, 08:13 AM
holland_patrick
good though that i haven't though about but was thinking about a sit down so i could easly build up the entery wall to contain it. should i get a premade basen or tile out the whole thing...
