Can u re-glue abs pipe?
Old 08-12-20, 11:44 PM
B
https://imgur.com/a/AUyfZ2C
The joint is slightly dripping after I twisted the joint by accident.
Can I try to pull it out, sand it, and re-glue it?
Old 08-13-20, 01:28 AM
Marq1's Avatar
Received 392 Votes on 366 Posts
So the joint was glued already?
Chance of getting it apart are slim to none, you will just need to cut it out and splice in new pipe and couplings!
Old 08-13-20, 03:13 AM
Received 330 Votes on 293 Posts
IF you can get it apart you should be able to sand/clean it and reglue BUT I agree that is easier said than done.
HTML code is On
