Riser clamp torque
Old 08-22-20, 05:41 AM
K
Received 1 Upvote on 1 Post
Riser clamp torque
I have a few holes developing in a my 70 year old cast stack.
I will cut out a section and replace it with PVC but will need to install a riser clamp above the cut.
How tight should the bolts on the riser clamp be to secure the pipe but not risk cracking the old cast?
thank you,
Old 08-22-20, 11:47 PM
Received 6 Upvotes on 4 Posts
I don't know if there's a setting for a torque wrench. I make them tight. If the riser clamp damages the cast, it's ready for replacement anyway. I don't mean to sound flippant but that's the best I can do.
Old 08-23-20, 06:14 AM
Marq1's Avatar
Received 1,100 Upvotes on 1,000 Posts
This is a Fernco style fitting?
Make sure the joint is clean, lightly torque you can always add more torque if needed!
Old 08-23-20, 05:20 PM
K
Thanks Steve,
Marq1,
No, a Fernco is 60 ft/pd, I can not find one manufacture that states a recommended torque for the bolts, so I guess Steve is right, just tighten until it "feels right"........and the pipe doesn't slip!
Old 08-24-20, 10:14 AM
Z
Received 365 Upvotes on 326 Posts
I did find a torque spec for one brand of riser clamps. For 4", it has a torque spec of 46lbs.
https://s3.amazonaws.com/anvilintl.c...HG-SUB-261.pdf
If possible, see if you can a riser clamp on a fitting above too just below a hub. It's obviously not always possible, but ensures that nothing will slip!
