Indentify diverter valve stem for handle replacement
I recently bought my first home and the diverter handle to my shower broke/came off. The stem itself looks like it's alright, and if it's that the case I'd love to replace all three handles with something more modern. From these pictures can the manufacturer be identified? Once identified, to clarify I can find/purchase OEM bushings to go on the stems to update the handles, is that correct? There are no leaks and I can turn the diverter stem with channel locks to switch the flow. Thank you for the help and suggestions in advance.
old handle
Diverter and Hot stems
Diverter stem close up
old handle
Welcome to the forums.
Good pictures.
Unfortunately the screw has broken off in the diverter valve so that insert/cartridge will need to be replaced. I don't recognize the manufacturer.
Is there a nut on the diverter shaft ? You may need to remove the insert to identify it.
Good pictures.
