Leak at 90 elbow
Old 08-29-20, 07:02 AM
Q
Received 1 Upvote on 1 Post
Leak at 90 elbow
[size=13px]Difficult to see in the picture but there was a small stub sticking out the floor under where the kitchen island goes. I made a joint with a 2" 90 bend under the island kickboard area so I could get the pipe towards the back of the island.[/size]
It seems this joint is leaking a bit, maybe I didn't get enough pipe weld on it or maybe didn't turn it enough.
Any easy way to fix it? As it is I'm guessing I need to lift the island off.
If I cut off the 90 then I have no stub left and would have to dig into the subfloor to get enough space for a union...
Can I just put epoxy resin around the elbow and seal it up?
Old 08-29-20, 07:24 AM
Marq1's Avatar
Received 1,103 Upvotes on 1,003 Posts
No idea what type of fittings your addressing but an external repair is not a long term solution!
Old 08-29-20, 09:28 AM
XSleeper's Avatar
Received 1,712 Upvotes on 1,536 Posts
What picture?
Old 08-30-20, 08:32 AM
Z
Received 366 Upvotes on 326 Posts
From what it sounds like (no pic), you'll have to cut out the fitting and possibly go down into the floor. There's no good way to seal a leak in a PVC fitting without redoing it. Some PVC cement or epoxy weld might work, but it also might fail down the road too. It's not something I'd recommend on a new installation - especially how diffiuclty it'll be to get to once the countertop and sink is in.
Old 08-30-20, 10:30 AM
P
Received 1,766 Upvotes on 1,579 Posts
Is this a threaded fitting or glue joint? What is the material? I'm confused because you say you used "pipe weld" but also mention "turning it enough".
