a trivia question - how long does it take for solids to get to the sewer main?
A bit of a trivia question here.
When you flush a toilet with 'solids'.... normally does that get all the way out to the street sewer mains just with that 1 - 2 flushes / water in the bowl / tank? And about how quickly?
The slope is very small, right? Seems to me, a noob, that cast iron is rough inside and for a pipe thats 10 - 20 - 30 years old, so many more rough spots for paper / solids to get hooked on / cause clogs?
I've heard that a greater slope is not good, but sewer lines are very gradual per code?
And yeah, there's cases (roots, misaligned pipe segments) when clogs do happen. But I'm speaking of a working system.
And any idea how long does that take to get out to the street? Not seconds, right? not hours?
Top Answer
09-12-20, 11:13 AM
That is not a wives tail. If the water moves too fast it leaves the solids behind.
Years ago when the town I lived in mandated low flow toilets a local plumber set up a mock system with PVC pipes cut in half to watch the flow but the slope was to code. No real poop was used but paper was flushed. Seems like a flush carried its own stuff many feet. Remember there are other sources of drainage water. I think if the solids from a flush get below where the dishwasher and clothes washer empty into the line that everything would be carried out to the main in that flow.
There is no such thing as too much slope, another wives tails dismissed!
I think the goal is that the flush should move most of the solids (waste/paper) all the way out to the sewer. There generally shouldn't be solids left behind. But of course I'm sure it varies based on the amount of water used in a flush and how much is.. ahem... being flushed.
If you've ever camera snaked a line, you'll see that a typical line is pretty clean. If you see something in it, there's usually something it snagged some other reason.
I, for one, have never had to clear a drain that stopped up because of too much slope. I've never heard of a drain that stopped up because of too much slope either.
Flat pipe... all the time.
Too much slope...never.
