lead pipe
Old 06-15-01, 05:08 PM
Guest
How do you connect a lead main water feed to
a copper line ?
Old 06-15-01, 05:19 PM
Mike Swearingen's Avatar
Cool
I doubt that you have a lead main water feed. It is galvanized steel.
Use two wraps of teflon tape on all male threads (clockwise only).
Since you have two different types of metal you will need a di-electric union to prevent electrolysis corrosion.
Good Luck!
Old 06-15-01, 05:35 PM
Guest
old guy
thank you for your help, but I think this pipe lead, it
is quite old and it very flexible, but I'm being carefull
not to crimp it. but if you have another idea I would appreciate it
Thank You
amw30
Old 06-16-01, 06:27 AM
Cool
IF you have a lead water supply pipe, you should replace it immediately.
Check with your local Health Department or call the US EPA at 1-800-424-LEAD regarding lead hazards or 1-800-426-4791 about the dangers of lead in drinking water.
Good Luck!
