toilet
Old 06-15-01, 06:10 PM
plhlp
Question
2nd floor toilet(20 years old) must be flushed twice. my third floor toilet no problem and first floor ok too. why won't it flush 1st time?? 1 family 60 yr old home.
Old 06-16-01, 06:52 AM
Mike Swearingen's Avatar
Cool
That toilet may be one of the low-flow so-called "water saver" toilets, or you may have a plastic toy, toothbrush, curler, etc., hung up in the built-in trap of the toilet.
Try feeding a plumber's auger snake into the trap and crank away. If that doesn't open it up, you may have to pull the toilet and try to dislodge it from underneath, if that is the problem.
Go to "Repair/Fix-It" above and to http://www.bhglive.com/homeimp/ and look in the Plumbing sections under Toilets for illustrated how-to info.
Good Luck!
