How to connect no-hub cast iron to old cast iron?
My city does not allow the use of plastics (ABS/PVC). I had a lead bent from toilet with a huge hole in it (probably from previous auger work) to old cast iron waste line. Removed lead bent and lead packing on old cast iron fitting. Now I need to connect new 4" cast iron to the old "bell" fitting of the old cast iron. How do I do that? Do they make Fenco doughnuts for that? Can I use an adapter that goes OVER the old hub and connects with the new?
Thanks!
Thanks!
Here's another source to buy the Fernco donuts, it's even a bit cheaper.
https://www.lowes.com/pd/Fernco-4-in...ing/1000075219
