Rusting Basement Floor Drain
Hello. The floor drain in my basement keeps rusting shut so the ball that floats up and down to let water drain, but keep sewer gas from coming up is stuck shut. Every time my water softener cycles, the drain get stuck shut causing a large pool of water around the drain until I reach it and break the ball loose.
Is there anything I can do to prevent this other than completely replacing the drain?
Thank You,
Lisa
Thank You,
Lisa
