What type of drain is this in my basement room
Old 10-19-20, 03:53 PM
Hi, I have basement with 2 rooms and a full bath. in one of my rooms in basement I see some type of drain, I am not sure what it is .. if you can identify and tell me how to close it for good,
I had carpet in that room so I removed it, and then to my surprise I found that there is this drain ? , so now i can not put floating/laminate floor,, I have to level it , and go around it, but I dont want to see any type of drain in the room.
see pic
Old 10-19-20, 04:07 PM
Received 3,422 Upvotes on 3,068 Posts
Is that a drain cover..... has holes in it or a blank plate/cover ?
Old 10-19-20, 05:47 PM
Left is drain pipe, right is cover. Cover does not have any holes in it
Old 10-19-20, 06:43 PM
What do you see when you look down in there ?
My first thought is that could be a cleanout.
CasualJoe voted this post useful.
Old 10-19-20, 06:56 PM
it is dry, no smell. and I see just 2 -3 dry papers clippings.
Can Clean out pipe smell? and how can it be in the room and less than 2 feet from a closet? and cover is not like pvc bolt, it just sits lose there
Old 10-20-20, 10:32 AM
Z
Received 367 Upvotes on 327 Posts
It's probably a cleanout of some type. It could be for your main sewer, or could be a cleanout for a foundation drain. With a loose fitting cap, I would guess a foundation drain... but it's just a guess.
Regardless, it probably shouldn't be completely sealed up as you may need to clean it out at some point. Even if you floor over it and make a note where it is just in case you need to open it up at some point.
Old 12-06-20, 02:22 PM
Thank you all for your reply, I just put floating floor over it.. in worst case we can undo the floor
Old 12-07-20, 11:30 AM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
Hopefully you will never find out. I once saw carpet over a floor drain in a commercial office space. That GC always had a good price.
Old 12-08-20, 09:46 AM
Z
I would suggest printing a picture or making a small drawing with measurements as to its location and pasting it inside a closet door or somewhere. If you ever find yourself needing a cleanout (or the next owner), it would be good to know where to look.
