Why is towel rail only heating up to a valve and only on 1 side
Hi
The only heat that my towel rail exhibits is low on the right hand side up as far as the valve,
None at all on the left or above.
I've tried bleeding and tried the valves in different positions.
Is it strange that there is heat in a small section?
Can you tell what the problem/solution is from this info?
Thanks
Heat is felt from the ground up to that point on the right
Thanks
Welcome to the forums from the UK.
You probably have air in there.
Your systems are set up different from ours. You need to find where to purge the air out.
It may require adding more water to the system to purge the air out and then remove the extra water.
Pictures of your system may help...... How-to-insert-pictures.
