Refrigerator Water Supply
Old 01-10-21, 12:20 PM
Hello all, I’m in the process of updating the kitchen and needed to add a water line for the refrigerator water supply. The nearest waterline is on the hot water heater supply line. I’ve added a tee fitting along with some reducers just after the shut off check valve just at the expansion tank just prior to entering the water heater. Is there any reason this won’t work as a temporary solution? I plan on calling a plumber to replace the water heater later this year and will tear down the wall behind it to have it connected properly. Here’s a photo. Thanks.
Popular Reply
01-10-21, 01:42 PM
Marq1's Avatar
Marq1
Marq1 is offline
Received 461 Votes on 430 Posts
Water is water, I would have added a shutoff off the tee just in case you needed to isolate!
Old 01-10-21, 01:42 PM
Marq1's Avatar
Baldwin, CasualJoe voted this post useful.
Old 01-10-21, 03:59 PM
Received 1,404 Votes on 1,299 Posts
The only problem I see is excessively hot water going to the fridge.
How long is that 1/4" copper line ?
Old 01-11-21, 02:32 AM
The 1/4” is roughly 50 feet and runs through the attic. I tried to run it under the insulation where I could.
I might add a shutoff valve to it if it’s going to be longer then a few months. My local hardware store didn’t have much of a selection.
