Water lines in slab
Water lines in slab
I have a house built in 1955 and the water lines are in or under the slab. There is a poured carport next to the back door with a 2’ x 2’ opening filled with gravel . Would this be where the water lines enter the house or would it be for something else ? Thanks
It could be anything but a square is usually left like that for some reason. The only way to know what's down there is to carefully dig.
Do you have city water or a well? There should be a meter above grade if you have city water. There should be a storage tank above grade if you have a well.
