Finding underground leak of sprinkler system
Old 04-11-21, 03:09 PM
There is an area (which is about 20ft x 10ft) on my lawn that is now muddy. I suspect there is a small leak in the underground pipes. I think if it was a big leak, it would produce a visible hole or pool of water. But I just have a very wet area.
To avoid randomly digging along all the pipes, is there a reliable way to pinpoint the leak to a more specific location before digging? Preferably not needing expensive professional tools.
Thanks
Old 04-11-21, 04:56 PM
Received 46 Upvotes on 39 Posts
If you know which irrigation zone has the leak, and you don't mind wasting a fair amount of water, just let the zone run for longer than usual. Eventually, if you're lucky, the soil will saturate and a squishy mound of turf will form above the leak, like a big zit. Pop the zit with a sharp tool and dig right there.
Old 04-13-21, 10:11 AM
Z
Received 367 Upvotes on 327 Posts
Most likely the leak is at a fitting. Pipes do leak, but it's much more rare than fitting leaks. So I'd start at any sprinkler head or where there might be a tee fitting.
You may be able to use a mechanic's stethescope to hear the leak - but with sprinklers running, it might be too loud in the area to use it effectively.
Old 04-13-21, 01:23 PM
Marq1's Avatar
Received 1,107 Upvotes on 1,007 Posts
You may be able to use a mechanic's stethoscope to hear the leak
Hmmm, well with water flowing through the pipe doubtful, not even sure what a leaking pipe would sound like!
Other than digging up the pipe, turn the water on and start lookin for the wet spot!
Old 04-14-21, 09:55 AM
Z
Yup - you're quite right Marq. Hearing dripping water over running water would be a challenge.
Suggestion withdrawn!
