Sink side overflow when garbage disposal is running...
Old 04-17-21, 10:23 PM
A
Received 4 Upvotes on 4 Posts
Hey Guys,
So recently my kitchen sink (left side) has been overflowing when the garbage disposal (right side) is running. These are the things I did:
1. The allen wrench trick under the the garbage disposal. To see if anything was stuck. It was moving freely.
2. I took apart all the pipes underneath and cleaned them thoroughly.
The issue was not solved. I realized that even if I let the water run on the left side, eventually the garbage disposal side will start to overflow, and vice versa. But all the pipes were clear. Here is a picture to show you where I cleaned.
If I'm still having issues, then could my issue be further down the pipe that leaves the kitchen? So I dumped some Max Gel on the left side, and things have improved. Now when I run water on the left side, the garbage side is not overflowing. However, when I look inside the garbage disposal drain, I can see standing water inside. Seems to be right at the height where the pipe connects to the left side sink. I figure this is normal but I'm not sure, since 've never looked before. So I'd like you guys to tell me if this is normal or not. Or, if I should keep cleaning using draino, max gel, etc. Or anything else you guys can think of that might be going on my situation. Thank you in advance.
Old 04-18-21, 05:03 AM
Norm201's Avatar
Received 672 Upvotes on 595 Posts
Stop using those God awful chemicals. You have a clog. Snake it out. Remove the trap under the sink and get a snake and snake it several times. And since you have used chemical be sure to have mask, eye protection and gloves on when removing the pipes.
Old 04-18-21, 08:59 AM
Received 3,422 Upvotes on 3,068 Posts
Your problem is going to be in the wall. Either at the stack location tee or below.
Old 04-18-21, 01:07 PM
A
The problem has been solved for now using max gel. Yeah, I wanted to avoid chemicals, but the dishes were piling. LOL! So for future reference... the problem is at the wall? Snake it out.. meaning using those drain augers?
Old 04-19-21, 10:28 AM
A
Next time, use something like this... Ryobi Auger, instead of chemicals?
Norm201 voted this post useful.
Old 04-19-21, 11:54 AM
Norm201's Avatar
Well, it doesn't need to be motorized, but yes that will work.
Old 04-19-21, 03:20 PM
I use the same type snake although it's not motorized.
I haven't come across a clog yet where it didn't perform.
