How to know if water is being used?
I'd like to be able to remotely monitor how much water my house is using. I would rather not cut into the main water pipe upstream of the water meter to insert one of the available wifi water flow sensors. Is there anything non-invasive that can be used - something strapped to the outside of the pipe (ultrasound sensor?) or some way of monitoring the water meter remotely, to know how much water is flowing?
Top Answer
04-27-21, 05:40 PM
I found a couple of candidates.
https://www.flows.com/clamp-on-smart-home-water-meter
https://www.amazon.com/Flume-Smart-H...dp/B07GPXKN8Z/
mlevin77
voted this post useful.
Unfortunately, I'm not aware of any device that can be installed without cutting into the pipes.
Some of the new internet-connected flow meters (that also have an app and shut off the water in case of a leak) have push-fit connections so it doesn't have to be soldered in place.
Another option might be a webcam pointed to your water meter, depending on its location.
