Sealing Around Pex
Old 05-10-21, 06:56 AM
W
Received 65 Upvotes on 56 Posts
Sealing Around Pex
What method should be used to seal around Pex tubing passing through bored holes in wood?
Old 05-10-21, 09:52 AM
Z
Received 425 Upvotes on 378 Posts
I usually use either caulk or expanding foam depending on the size of the hole.
PEX is pretty resilient, so just about anything should be fine short of really harsh chemicals.
Old 05-10-21, 09:53 AM
Received 4,051 Upvotes on 3,634 Posts
Normally it's not sealed between joists or studs unless you're firestopping.
It does shrink and expand with heat.
Suspension clamps are the best method.
Using expansion clamps video
Old 05-11-21, 07:00 AM
W
My application is water tubing passing through floor and base cabinet from basement to kitchen sink.
Old 05-11-21, 09:01 AM
P
Received 2,229 Upvotes on 1,988 Posts
Holes between floors need to be sealed with fireproof caulk/foam, usually an orange color. The hole through the base of the cabinet can be sealed with an escutcheon plate or regular foam or caulk.
Zorfdt voted this post useful.
Old 05-12-21, 07:06 AM
W
Thanks for the help, everyone.
